An all-in-one printer and scanner with duplex print and WiFi connection.
Canon printer MG5250 not start
hi ..
I have canon mp5250 printer it won't start when i push power button , but some times its start for less than 1 min maybe then power gone again and dead !
at the beginning it was have error B200 , i just open the cover and moved the print head to the middle and re turn it on then i closer the cover when the head was at the left , after that i faced that problem of power
any ideas ?
Thank you.
If your Canon MG5250 printer is not starting, there could be several reasons behind the issue. Here are some steps you can take to troubleshoot and potentially resolve the problem:
1. Check Power Supply
  • Power Cable: Make sure the power cable is securely connected to both the printer and the electrical outlet.
  • Power Button: Press the power button firmly and check if any lights come on. If nothing happens, there might be an issue with the power supply.
2. Check for Error Messages or Lights
  • Look at the printer’s display panel (if available) or any indicator lights. Any flashing lights or error codes could provide a clue as to what's wrong.
  • If there's an error code, consult the printer’s manual or the Canon support website for more details.
3. Unplug and Reset
  • Unplug the Printer: Disconnect the printer from the power outlet and leave it unplugged for about 5-10 minutes. This will allow any internal components to reset.
  • Plug it Back In: After the reset time, plug the printer back in and press the power button to check if it starts.
4. Check the Power Supply Unit (PSU)
  • If you are still unable to power up the printer, the internal power supply could be faulty. Unfortunately, repairing or replacing the power supply usually requires professional help.
5. Check for Paper Jams or Blockages
  • Sometimes, paper jams or blockages inside the printer can prevent it from starting up.
  • Open the printer’s cover and check for any paper stuck inside. Clear any jams and try powering on the printer again.
6. Ink Cartridges
  • If the ink cartridges are not properly installed or are missing, the printer might not start.
  • Make sure the ink cartridges are correctly seated in their slots.
7. Software or Driver Issue
  • If the printer is not starting from the computer side, there could be a software or driver issue. Try reinstalling the printer drivers on your computer.
  • You can download the latest drivers from the Canon website.
8. Try a Different Power Outlet
  • Test the printer by plugging it into a different electrical outlet to rule out any issues with the current outlet.
9. Service or Repair
  • If none of the above steps work, the printer may have a deeper hardware issue, such as a faulty motherboard or power supply.
  • Contact Canon customer support or a local service center for professional repair assistance.
Omar 2 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 142
