Released 2014, October; Android 0S, v4.4.4, up to v5.1; 32/64GB storage and exclusive to Verizon Wireless.
Charging port not snug
The charging cable is very loose in the phone charging port. Can I get parts to replace the port on my Droid Turbo Power/
Did you check with a different cable? micro-usb is kind of designed that the cable fails rather then port. If still problem:
Search in eBay (depends on the country)...
@markus2 Thanks for your answer. I have tried other cables and still have the same problem. The cables work on other phones.
Well then in eBay.com you can find the charging port around $4. Of course, there are perhaps no manuals for charging port replacement: Start with Motorola Droid Turbo Battery Replacement
May be it helps.
You can take it to a technician for repair. Lose charging socket is a common thing and very easy and cheap to fix.
Do that before occupying yourself with installing new parts. You may not have to.
Robert Bruns crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 100
