The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
Why won’t my truck start
My 06 fl50 is a v8 supercharged but the motor locked and my stepdad got a v6 installed in it. I wanna say prolly a few weeks I into having it my dad put some speakers n a radio in it and it caused my dash to go out . Last night my truck was running hot and we noticed it when it started to like stall on going .
I need more information? Did you overheat it? Is there water in the oil or oil in the radiator? Can you run a compression test on the engine?
Hello most definitely we need more info cause it sounds like you got multiple issues with your truck. if your dash lights are still off. Most likely you may have blown a fuse. I would start with disconnect all of the radio wires and check the fuses. Then make sure you wire the speakers and radio correctly. I Agree you need to check the radiator to make sure there is fluid in it and in the overfill tank. I would also agree check the engine oil to make sure the engine did not blow a gasket or if something happen to the engine. If there is fluid and the engine is not cross contaminated with radiator fluid then let us know does the engine run normally till it gets to the hot condition. I do not know if the radiator fan is electrical or not. If it is not electrical check the radiator fan is moving and when the engine is getting hot to confirm the fan it is pulling air through the radiator. When you switched it from v8 to v6 they may not have changed the fan shroud to compensate for the smaller engine.
Malik solomon crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 113
