Repair and disassembly instructions for Jura Impressa F50 fully automatic coffee machines
Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
crwdns2886500:0Jura Capresso IMPRESSA J5crwdne2886500:0
crwdns2930805:0crwdne2930805:0
Jura Capresso IMPRESSA J5 Drainage Valve disassembly
crwdns2934079:0crwdne2934079:0
crwdns2937799:0crwdne2937799:0
5 - 10 minutes
crwdns2886500:0Jura Impressa C E F Modelle Heatercrwdne2886500:0
Jura Heater Replacement
crwdns2937801:0crwdne2937801:0
1 hour
crwdns2886500:0Jura Impressa C E F Modellecrwdne2886500:0
Remove Jura Brew unit
9 - 15 minutes
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
It's much cheaper just to replace the gasket or the valve of the tank.
Colin Brown crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,586
