Repair guides and support for coffee makers by Keurig including the K-Cup systems.
My Keurig wont open or close
The top will not open or close it’s stuck what can I do?
Hello Lisa,
I have never had this problem myself, but found this information online. Sounds like it could be the same issue, although this is in the context of a lid that’s stuck open as opposed to stuck closed. Let me know if this helps!
“Sometimes after you unclog the needles and check the tubes just to make sure everything is alright, the top refuses to close.
You look inside to find the metal tongue located behind the holder for K-cups completely locked in and rigid. So much so that the bar responsible for sliding over that tongue into the groove refuses to budge. And that means it becomes impossible for you to force the handle shut against all that pressure.
You obviously didn’t do anything to create this problem. So what can you do to fix it?
Remove your Keurig’s upper cover and the two screws. You might find a piece of plastic keeping the mechanism from shutting. This has happened with a lot of users, and nobody knows how the plastic piece got there in the first place. Anyway, just remove it for your machine to open and close like new.
But if there’s no such plastic piece, then try this. Turn your Keurig upside down to drain out the water for removing the screws. At this point, the cover should go down on its own.”
-Felicia
This issue is NOT a plastic piece got stuck. There is a plastic tab that breaks off and prevents the lid from closing. The first time this happens there should be a small 1/2 in x 1/2 in plastic broken and at the bottom of the machine. Unless the space is filled where the plastic tab came out, the lid will hang up and not close.
The Kureug KDuo is notorious for this.
There are many post about this.
It has to be 8nsertee perfectly in the TOP track. I fiddled for 10 minutes today. I was about to return it to store when my daughter-in-law came in and showed me.
The back patrusion on the tray has to go perfectly INTO the slide at top of coffee maker. If it's under the tray will jam up.
Itsca Definite Design Flaw I expect Keurig will eventually change.
FYI those posting "I've never had this problem" .... Then why are you posting Anything in an Answer Column? Geeeze!
Lisa Craig crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 7,081
