Whoa...lemme get this straight, you know your amp is 110v and you plugged it into a 220v on purpose? Now you're surprised it doesn't turn on?
That little black thing attached to the heatsink is a power transistor (To 220 I believe) and it has obviously seen a massive overvoltage and is fried…I’d start with that, but don’t be surprised if there’s more that needs to be replaced. That heatsink is strictly for the power transistor as they get very hot.
Good luck, you may need it…
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
@weqs ... according to your board, if you fix the issue that the 220v on a 110v caused, you can re wire the system to be rated at 220v. look at the power supply board next to the ac adapter. printed right there on the board. will need the proper components and research to do so. good luck.
crwdns2934271:0crwdnd2934271:0 jostewcrew crwdne2934271:0
