Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
Play for few seconds
Hi, My VCR-Video-8 combo SONY SLV-T2000 , VHS repaired for loading, now it only plays and Fast forward for 2-3 seconds than stops! Rewind is working.
Sorry to revive a dead post but I have the EXACT same issue! My SLV-T2000 would eat tapes when ejecting and wouldn't play anything. I fixed the loading issue, and now it plays but only for 4 seconds and then stops. Did you find a solution in the end?
The gear related to the function might be damaged (skipping some teeth probably).
See if you can open it up and pinpoint the issue.
If this is the case, it would be quite troublesome to find an identical part, i’d try restoring the existing gear.
I had the exact same issue with my SLV-T2000 and it did cost me multiple days and nights to find the solution to this. As the VCR never worked I never fully assembled it. I always had the same issue, VHS played then stopped after a few seconds. I also noticed that Auto Tracking blinked (Manual Tracking did not fix this). So I fully assembled the Device and put ALL screws in. The ones on the bottom, that I never screwed in because I just wanted to test the Deck.
It was the following: The S.REEL/T.REEL Sensors could not work properly because Deck was not properly mounted without the screw on the bottom.
I hope I can help someone with this Information. :)
kavuly crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2959996:0crwdne2959996:0 1,193
