Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
Why does my PSP GO screen remains blank?
I was playing a game when the PSP Go accidentaly fell. It wasn't from a great height and it wasn't that hard. When I picked it up, the screen was blank so I turned it off for a few minutes and turned it back on. I could hear the startup tone and the XMB clicking when I move the buttons but the screen remains blank. It charges when I connect the charger and even goes to 'USB mode' when i connect the cable to my PC but the PSP GO screen remains blank. Any help?
is there any display damaged if not then change the ribbon cable will fix it
crwdns2933315:06crwdne2933315:0
The first place I would suspect the problem to be is the display connection to the motherboard. I would try reseating it. The gist of the instructions for doing that are here. More than likely the flap that holds the cable in has popped up or the cable has shifted.
turn on while pressing left arrow key and Bang screen is back.
This exact situation just happened to me. My down arrow key felt stuck and I just held it in while turning on and bam. Can't believe that actually worked. Literal legend
F@#$ legend got mine back up too thank you king.
Same case with mine PSP Go white (Japanese model). I followed the instructions (i.e. turn on while pressing left arrow key on the d-pad) and it came back to life! Thanks a lot man!
i was also having same problem like this twice but it's is soo easy to installed my psp go. this is the black screen of the psp go is nothing wrong but i have used the new display ribbon cable & i have change it. there was only problem was my display ribbon cable which was little bit cut off when i fall down my psp go & i buy it from eachgame.com at us$ 14.59.
the screen remain black because the ribbon cable have been damaged by falling down so i suggest every psp go user to change the ribbon cable when u having black screen but ur psp should respond & indicate the green light & it should be on when u on ur psp go for a while
Update
did ur psp go turn off automatically.
try thisworks in 6.35 pro b7 i'd ever tried to other version hope it will work if your psp has a vsh menu, first you must have a cable that can transfer your display into television that is via connected display settings... of coarse you dont know how to connect it because you got black screen right, here are the things you ca do turn off your psp then connect the cable now turn it on again wait about 5 seconds after the welcome sounds done now press left all the way until the clicking sound is gone then press down until the clicking sound is also gone then press up 4x or 4 clicking sound press the x or enter you will hear the warning sound then press 1 left or 1 clicking sound then press enter or x, now your display is on your television, ow if you have fast recover pro-b wait for reboot now press select botton make sure that your cpu clock xmb, cpu clock game is i default ow press the suspend device your psp will put on sleep the slide up or turn on your device now your done display on your psp go the reaso why your psp put into black its because the program bug so sometimes we need to stimulate it like a cardiac arrest defibrilize, or cpr... sorry for my bad english hope you got it
i have connected my psp go with my laptop but in laptop the folder of psp is showing empty yet in properties it has used space
Can you help me???
It is also the same issue but my console didnt fall out of any... its just that when i am playing it does turn black screen.
But i have a habit of always pressing the PSP icon everytime i play... is that an issue to cause the console to occur a black screen?
is there a movement i ur display while pressing the psp icon.
Kevin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 35,998
