The Cadillac DeVille was originally a trim level and later a separate model produced by Cadillac. The first car to bear the name was the 1949 Coupe de Ville, a prestige trim level of the Series 62 luxury coupe.
Windows, gas gauge, ac, and miles till empty
Windows, gas gauge, miles till empty, and ac controls don't work. I've replaced the 10 amp fuse in the trunk labeled comfort I believe and still nothing
You need to get a working schematic and trace the power supply. They use something called a fusible link which the wire in the insulation will melt if the load gets to high. It's a piece of wire that's a fuse and the only way to find it is to find it location and test it with a test light or a voltmeter. It could also have a different fuse. I guarantee that a Cadillac has at least 2 fuse boxes. You need to check the schematics and find was has interrupted the power supply. Unless you have a lot electrical experience I would take it to a EXPERIENCE MECHANIC Cadillacs have A LOT of wiring and and it will be difficult to find the issue. But first check that all of the fuseboc/ fuse boxes have been found and manually check each fuse with a test light or voltmeter.
arnold williamson crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 174
