Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
crwdns2934591:0398crwdne2934591:0 crwdns2934593:0crwdne2934593:0
iPhone XS earspeaker not working after screen replacement
Just recently replaced a iPhone XS screen and pretty sure before the earspeaker worked now after the screen replacement it doesn’t, Face ID proximity sensor front camera etc all work just not the earspeaker unsure why
Any help would be great
thanks
You could have damaged the solder joints on the cable. You can replace the the earpiece speaker. But my guess is a bad connection to the motherboard. Remove that connector and make sure all of the pins are straight and clean the connector with alcohol and a qtip and a soft brush. I actually had the same problem with xs max and it was the connection.
Update (06/08/2020)
Yes that fixed the issue. I would first check the solder joints on the cable and earpiece speaker and then check the connection to the motherboard and make sure the pins aren't damaged and clean it and hopefully that will solve your problems.
crwdns2942205:01crwdne2942205:0:
Did that fix the issue?
Kris Madhav crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,112
