The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
Why is my car not firing?
I have changed the plugs and wires and still no fire to them. What all can I check to fix this problem?
crwdns2889612:0crwdne2889612:0 -1
Of course the engine turns over, and there's a spark from the coil wire?
Check your crank sensor. It is the crank sensor that sends a signal to the PCM, this signal determines when the PCM fires the coil. So I would check crank sensor then PCM for spark. You can download the ignition part from the service manual right here good luck and I hope this will work for you.
jamey crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,265
