Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
I replaced the screen on iPad 2 and I received a Black screen!
I replaced the screen in iPad 2,3.
After that I received a black screen.
The screen is completely black as when is off.
when I turn it I have the same screen. I don’t have illuminated light. Black complete as when is off!
i checked the LCD is working with another iPad so it’s not the LCD. Also I opened the motherboard and I saw that
I there is a blown fuse. Please took a look the picture.
Can we say that this fuse was blown??? Could somebody confirm it?
could be if I replace it will began to work????
Any suggestions will be highly appreciated!
thank you
Vinnie Venkov
No picture. Did you disconnect the battery before you unhooked the lcd and digitizer? It sounds like you shorted the backlight circuit.
Thank you Allan. Also I"m sorry for the picture, now You can see it. I had a problem to upload the picture thats why wasn't there. So do you thing this could be a problem on the picture. Also pls give advise if You know where I can buy all those small parts fuse, transistors etc, if You know. Thank You so much for Your help!!!
Vinnie crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 83
