I just got my hands on an original (2011) 3DS with a broken 3D slider. The slider itself, well, slides, but it doesn’t change anything. The console is stuck permanently in 3D mode.
How do I fix it? I’m willing to crack open the 3DS as my final goal is to completely fix it and keep it. :)
IMPORTANT Don't format or factory reset the 3DS if the 3D slider is broken because you won't be able to get past the Initial Setup Wizard and the device will be soft-locked until it is repaired. During the initialization you must be able to adjust the 3D settings using the slider and if it doesn't work you can't complete the initialization and the 3DS will be unusable.
I’m affraid this is a hardware fault.. But you could try the simple basics first. Full system reset, check if there is dust inside there, try an air blower ect. Perhaps the slider is not seated correctly to the switch.
The slider have it’s own PCB and is connected with a ribbon cable to the PCB where the speakers are connected. It’s fixable, but it won’t be easy.. You also need to heat the glass panel too.
Your welcome! Yes, you need to go all the way as in the tutorial. But you need to stop at step 27. You can replace the 3D switch from here :). It's connected with a ribbon cable to the speaker PCB. You need to replace the whole 3D switch PCB (it should come with a new ribbon cable too). After it's replaced, build it together and test.
I have the same problem but it's with the internet slider. I just got the 3ds and I can't use the internet.
crwdns2957956:0crwdnd2957956:0 Gdog of Llama clan crwdne2957956:0
crwdns2957956:0crwdnd2957956:0 Wreck Gear crwdne2957956:0
