The 2018 version of the Samsung Galaxy A8+ smartphone released in January 2018.
Water sensor alert wont go away when triggered
Ever since i dropped the phone in a puddle of salt water at the beach the water sensor alert comes up and is almost impossible to go away, i was on 2% and desprate to charge it, the only way i could bypass it was to reboot the phone and plug it in while it was starting up, but the phone is kinda glitchy when i do that, and now almost everytime the phone gets even a little bit wet it triggers the water sensor and i have to reboot the phone and plug it in while booting to trick the system and be able to charge my phone, this is getting annoying, how do i fix this?
Luckily that phone is IP68 dust and water resistant. Salt water can be highly corrosive and probably caused corrosion in the port, causing a short circuit which results in that message and stopping the phone from charging. You can use a toothbrush and some compressed air to clean it out. If you have something like a pipette you can use that to drop a little rubbing alcohol in there to help clean it. Just be sure to power the phone off when you do so.
Finger print does not working
Fingerprint does not working
Bryn Trainor crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 293
