Getting the blaze battery sent to Canada
The battery in my Fitbit Blaze is toast and I need a replacement. However, I live in Canada and the battery replacement sold by iFixit (IF384-000-1) cannot currently be shipped across the border. Does anyone know where I could find one of these in Canada?
crwdns2886500:0Replace a 170 mAh battery compatible with the Fitbit Blaze smartwatch. 3.7 Volts (V).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Fitbit Blaze Battery
$19.99
Hi @alenux ,
Does your original battery have a 6 digit code number on it at all? The number gives the dimensions of the battery
The convention with batteries is that the 1st two digits are the height of the battery in mm and there is a decimal point between the two digits which is not shown, the next two digits are the width in mm and the last two are the length in mm, e.g. 252020 = 2.5mm H x 20mm W x 20mm L
If so try searching for (insert 6 digit number) 3.7V LiPo battery that has the same or better capacity i.e. mAH.
If you can’t find an exact match try for one a bit smaller in size, especially height, as it has to physically fit into the watch.
Just ensure that the voltage (V) is exactly the same as the original, as the capacity (mAH) only determines the length of time that the battery will last before needing a recharge.
The numbers listed on the battery don’t seem to correspond to the size. I see:
LSSP321830AE
5C30 46159
Looks like the dimensions for this battery (including the protection PCB) are 1.8 mm x 2.9 mm x 0.3 mm. The original battery claims to be 167 mAH, but all the replacements I see are 120 mAH unfortunately.
@alenux
OK,
Maybe you could try one of these suppliers and see if they ship to your location.
Alex Naylor crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 128
