Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Why is my home button always down?
The iPad keeps taking pictures when I try to turn off the iPad, it keep double clicking when I only press the home button once, the iPad keeps signaling for Siri, and it keeps pulling up random tabs and jumping between apps
Does it look like the home button is physically pushed down into the screen assembly? It sounds like the bracket for home button might have broken loose from the screen assembly. It might also have something sticky on the home button to cause it to stick. You are going to have to take the screen off and check what is the problem. You can change the home button but you will lose touch Id. The factory home button is matched to the motherboard so an aftermarket home button will work but touch Id won't. I would try to fix the original home button first.
Mary Rohde crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 38
