Movies, music, multimedia in your home. Use our guides to repair home entertainment devices from surround sound A/V receivers or conventional stereo receivers to power amplifiers, preamplifier, speakers, and iPod/Bluetooth speaker systems.
Hi-Fi Component System not functioning normally.
I have a Sony HCD-RXD5 Stereo. Every time I turn it on, it makes a buzzing sound, and I see ,’’Push Power, Protect’’ on the display. This has been happening for a week now. What could be the cause, and how could this issue be resolved?
Vaughn Gracey  directly from Sony :” If the words PROTECT / PROTECTOR and PUSH POWER appear in alternating sequence on the display of your home audio device, or if the words PROTECT or PROTECTOR appear, there may be an external speaker issue or connection issue that is triggering the protection circuit. Try following these steps to resolve this issue:
NOTE: Because each of these steps represents a possible solution to this issue, check the A/V receiver status after completing each step.
  1. If there has been an electrical surge or power outage, then the internal surge protection inside the home audio device may have been triggered to protect the device from the surge. This is normal. To reset the internal surge protection circuit unplug the AC power cord from the wall for at least 30 minutes.
  1. Ensure the top of the home audio device has proper ventilation to keep it from overheating. Running the home audio device in a poorly ventilated cabinet can trigger the protection circuit.
  1. Reduce the volume level. If the impedance of any of the speakers is below the rated impedance range indicated on the rear of the home audio device next to the speaker connections, the home audio device may enter the PROTECT mode. Raising the volume with a low impedance speaker will trigger the protection circuit.
  2. NOTES:
    • Replace low impedance (outside of specifications) speakers with the correct impedance to prevent this from occurring.
    • If you continue to use the low impedance (outside of specifications) speakers and you ran the Auto Calibration, check your SPEAKER SETUP and individual speaker LEVEL to reduce any speaker LEVEL with a positive gain to 0.0dB or less.
  1. To isolate the problem, do the following:
    1. Turn off the home audio device, and remove all speaker wires from the back. Then turn the device back on and check if the issue is resolved. If it is still having the same issue, turn off the device again and let it rest for at least 30 minutes before turning it on again.
    2. Inspect the speaker cords. If a cord is frayed or in contact with another terminal, an error will occur. Fix the connection to prevent a short circuit.
    3. Make sure the speaker impedance is within the recommended range. If the impedance is not correct, sound will not come out properly and the speaker may be damaged. If speakers that are within the recommended impedance range, check the connections. If the speakers being used is within the suitable range and is still not working, there may be a malfunction or some other flaw within the speakers. Test by using a different set of speakers if available.”
    4. So, check your speakers first, including the wiring etc. Let us jknow what you find
My sony home theater surround speakers voice goes down and the base remains
Vaughn Gracey crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 94
