Blown key ignition fuse
I have an 89 Club Car DS has powered. Car was running great and started with no issues. Until! I noticed the LED strip lights under the car were not on. I went to reconnect the wire that had come off the back of the ignition when I pulled the dash for access. While reconnecting I was trying to find the correct area to attach the wire to the ignition and there was a spark. That is where my fuse blew. No problem if I could just buy a new one. WELL that part is no longer available. This fuse/module was mounted to the frame just behind the dash. I tried a fuse/breaker that dealer said would work. It didn’t. I’m wondering if I can bypass this fuse and/or just jump the wires together. Please help thank you JD
