Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
Is it possible to change the housing?
Hey guys,
has anyone ever attempted to change the housing of the Apple Watch 3?
I have a broken S3 42mm LTE Version laying around and idk if I should only replace the LCD and battery or the housing too, because its a bit scratched. If anyone has done this job, how do you replaced the heart rate sensor? I think it is spotwelded or so but how can I do this after replacement for waterproofness?
Hope someone can help me :)
Felix
I can't see that the cases are available from my supplier but that doesn't mean that they aren't available from someone else. You can get all of the parts to repair the phone for around 200 dollars depending on the supplier. You just need to know if it is just cellular or cellular and GPS before you order the parts to make sure you get the correct parts. The prices can vary a little depending on the model also.
I already found the parts I need on aliexpress (aliexpress.com) but idk if it is possible to swap the housing without soldering on the mainboard...In addition to that I want that the watch is still waterproof after the repair so how is the heart beat sensor fixed in the housing?
Btw it is a watch and not a phone ;D
Yes I know, did I say it was a phone? If I did I apologize but the information I gave you is correct
There is a video on YouTube from ifixit that shows the teardown and he said the the lower part is soldered on, on the LTE version and he said he didn't want to destroy it. You would think that a person who does micrsoldering could change it. I would check with some shops
Felix Hubenthal crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 804
