The Huawei IDEOS U8150 is a mobile phone manufactured by Huawei, Inc.
smart phone wont turn on at all?
oh god am so stressed ..my huawei u8150 smart phone was working jus fine then i look away for a minute and it cant start at all,cant charge,nothing!even the light that indicates its charging is not seen ..am pretty sure its not the battery because i tried it on my sister's phone(which is the same make as mine) and it worked..i really dont know what to do since I've tried every advice I've found on the internet but nothings worked ..i have no money to buy a new phone so please anyone who can help me you'd be saving my life..anyone..please
crwdns2889612:0crwdne2889612:0 20
crwdns2944067:08crwdne2944067:0
i factory reset my huawei gr3 it turned off but didnt turn on again
no on mpoile
Huawei model charging plang power on problem
I have the same prob;em, but my phone has a low battery sign and no matter what i do it won't charge. Please help?
i have the same problem and nothing works out !! i guess huawei phones are really sucks :(
crwdns2933315:016crwdne2933315:0
If it is completely dead, and you tried a different charging cable, then I'm thinking you have a problem with the logic board. Or, the battery could have drained completely and when your trying to turn it on the power button is faulty.
Can something be done
I had a Huawei Y350 and I've been told that it died but I'm still hoping that the man was wrong cause I had some important data on it when I put it to charge the red light that shows its charging it's on but the phone would never charge no matter how long I leave it like that so could it be the battery that small charging lamp light is still my hope ?
Hold the on button and the home screen button down at the same time for about 15 seconds. If this does not work hold the on button down and the volume up or down button down for about 15 seconds. Works every time for me on my android phone or tablet. Good luck.
crwdns2889612:0crwdne2889612:0 15
crwdns2944067:011crwdne2944067:0:
thank you so much , it worked for my Vodafone Smart 4 Max .
thank you. this one helped me :D.
yeah!!! it work for my huawei. Thankz a lot
hey guys.i have huawei ascend Y330 and home screen button umm isn't like button :/ i tried with volume up or down and button down but it dont worked please help me(
omg.... this method is really working
thanks thanks thanks
thank you very much
crwdns2934275:06crwdne2934275:0
Judy, if nothing else has happened to your phone, try a hard reset. I think it is done by powering off the phone hold the volume up button the send button and turn the phone on. Let us know if this helps.
I've tried doing that it doesn't seem to be working..but i could possibly have accidentally banged it without knowing..do you think that could be the cause?any other ideas?
Have you tried to charge it on a AC (Wall) charger. Try a different cable. It should not be dead from a simple single bang.
my huawei y511 needs to be flush then i flushed it but after that the phone completely dead and i can't turn the power on. pls guys help me with it
My huawei y536a1 won't turn on now after I took the battery out and put it back in. What ahould I do
Try removing the battery and leave it out. Then plug the phone's power cable in while the battery is out. See if the phone will power on. If it does you simply need a new battery. If it doesn't then that little bump it took killed something on the main board and it will need to go back to the store to be replaced.
My Huawei y8 2019 did not turn on after being charged overnight. There was no battery left when I charged it, like literally the phone turned off. The next day I tried turning it on but it wouldn’t turn on. The light didn’t show up my I charged it. What I did was I leave my phone for a while like 10 minutes, uncharged. Then after that I tried holding the volume down button and power button at the same time for 15 secs but nothing showed up so i tried holding volume up button and power button yet still nothing. I felt hopeless. Then I left it for a while again and later I tried charging it. Finally the red light shows up but nothing on the screen. My battery must’ve been drained so much. So I left the phone charging. After a few minutes I went back to check on it and saw that there was 0 percent and left it for 2 hours until fully charged
My huawai p smart 2019 just stopped working suddenly, it just went off
help, my phone Lenovo A789 wont turn on. my computer doesn't recognize anything when i connect it, and neither does it charge.. although it was working just fine..
please help!
mine is huawei g526 when i try to plug the cable without the battery, the led light just turn on half a second color orange. when i try to plug it with the battery nothing happened. no light no anything.
it was charging when it died.. its on 96 percent charging. now i cant open it. help pls.
I think that you should just take it to a shop(that's cheap) to see what's wrong with it. If it's broken then you can sell your phone somewhere and use that money to pay for a new one. Hope this helps:)
Sometimes there's a little chip inside of the phone that controls the storage, and everything else. You can look for a close-up diagram of your phone to see what I'm talking about. Also, the quality of the phone depends on where you get it, how new it was, and how much you paid for it. Yes, I understand phones are expensive, but make sure you buy one that isn't ridiculously cheap. Like the saying, "You get what you pay for." I hope this helps.
Try removing the SD card if you have one and put it back in that usually fixes it for my metro PCS
hello
huawei y511 i flushed it but after that the phone completely dead and i can't turn the power on. pls guys help me with it
please i can not install playstore on my phone,it keep tell me no ID passed with URI help me
slovesaltlife@gmail.com or theonat2016@gmail.com
Hello
I just bought a new Hawei P Smart we started and the next moment dead. I don't know if it is charging and wont turn on either so please Help.
I am waiting for your answer
Ps I am texting on my old phone
Hi Anna - Mart, did you get your phone fixed? I have they same issue with my Huawei P Smart since this morning. Any suggestions?
Thank you.
I will replace all your phone here just message me or comment your issue.
Hello
My phone (huawei p10 lite) is completely dead after a hit in the wall.
The screen is ok but I cannot turn on the phone by any occasion.
I’ve tried a lot of recovery tools but all they need to turn on the device so it can be detected. Obviously that’s not happening in my case.
I gave the phone to a phone service shop and they said they cannot do anything about it.
Do you have any ideas how I can get my data from my phone at least ?
Thanks in advance.
My name is Choma my
Huawei p40 pro + 5g left on a charge overnight next it was off no charging light nothing at all and does not even come on
Mr choma the same is true for my phone what can I do?
my hauwei p smart 2019 has turnt off and will not turn back on again. ive had it for about a year now, no problems at all. about a month ago the volume stopped working and now only works with bluetooth headphones. about 20 minutes ago my phone died, i put it on charge but nothing is happening, it wont charge. it wont turn on, any ideas??? i havent done anything to my phone that couldve caused this either
Judy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 67,484
