Risk of battery fire after logic board spark
I've had this MacBook pro since 2013 and in 2015 juice was spilled on it and it no longer worked. Now, 5 years later I decided to take a look at the laptop and see if I could clean it up and fix it. I took it apart, cleaned it with alcohol, and reassembled it. I powered it on and it worked for a couple of minutes, the batteries charged to 12%, but then it shut down. I tried to power it back on but the backlight kept coming on and off and no boot. I went to disconnect the battery from the logic board but when my screwdriver touched the screw on the connector it sparked. Fearing that the batteries may catch fire I put it outside for now. Does anyone know the likelyhood that the batteries may catch fire. Keeping in mind the batteries have been sitting for about 5 years.
Unless the battery has been punctured or has swollen there is little risk of fire. Next time use your fingernail or a sponger.
The OEM batteries are pretty good when it comes to sparks, worse case scenario you damaged the logic board or, believe it or not, there’s a circuit board in the battery. Liquid damage should’ve been addressed immediately. You might have luck sending it to Louis Rossman for data recovery at least.
Alexander Vlasopoulos crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 227
