This laptop was released in February 2000 and was discontinued in January 2001. The model number is M7572.
System will not startup - Dead Battery?
Aloha All,
My friend has a Apple PowerBook G3 400. The powerbook laptop battery is dead and will not charge. I have removed the battery and just plugged in the AC Adapter. The system will still not start up. Could it be that I will need to get a replacement battery to get the system to boot?
Thanks,
supertechhawaii
Before you worry about the battery pull the PRAM battery--its easy just open the keyboard. I'll include a link for you. In these models a bad PRAM battery will keep the computer from booting and you can run it without the battery. You do not need to disconnect the keyboard to disconnect the battery.
Good luck.
PowerBook G3 Pismo PRAM Battery Replacement
Aloha rj713,
Thanks for the help and the link :) Is the PRAM chip a standard 3V button battery?
Thanks,
supertechhawaii
Unfortunately its not. It's a fairly expensive battery and if connected to the web not really needed. Just select time in system preferences and select automatic update. Otherwise you will need to set time and date when you boot the computer.. Link to used battery included.
http://www.ebay.com/itm/PowerBook-G3-Pis...
supertechhawaii crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,354
