baterry shows 100%, yet when I unplug the power cord, it turns off
when i unplug the power cord, my computer turns off, even though the baterry shows 100%
If the battery/computer…
Batteries are very tricky. Because you have to think of them as fuel tanks. Batteries have a capacity, and when you charge them you're refilling the tank. Although, over time after several drains and refueling. The actual capacity gets smaller and smaller. So it's charging to 100% of the very little to no capacity.
As weird as it sounds this is actually really bad for the battery. Yes, it does keep it charged constantly but batteries do have a “memory" to say the least. If a battery doesn't get the chance to deplete and refill, its at a constant state of depleting. Rather than refilling.
What happens is the battery voltage goes below the amount needed to power the device on its own and applying the power charging source is barely putting it past that threshold for it to work as it's plugged in but not unplugged.
This goes hand in hand with the previous one. When batteries are made they're sent to a warehouse until sold. So they're “New" because they haven't been used but they're not charged while waiting to be sold and discharging.
Overall a new battery will fix the issue. My recommendation go to a Battery Store such as Batteries Plus Bulbs. They'll get there batteries fresh each month and maintain them as well as they'll come with warranties. You'll pay more but it's cheaper than a new laptop.
If these do not fit the criteria of your issues then I would recommend contacting the manufacturer.
Hi @tcashew
Create a Win 10 battery report to find out the state of the battery.
Even though is shows 100% it may not be able to supply the necessary power when a load is connected to it.
It may be caused by two reasons:
Update or upgrade windows 10
If you’ve recently upgraded the operating system of your laptop to Windows 10 or updated to the 1809 update, maybe this is the reason for the issue.
Faulty battery
On the off chance that your PC closes down once you unplug the connector, it normally implies your battery isn't working as expected.
Well may be you need to change your battery and replace it with the new battery it might help in fixing the issue.
I had the same issue and changing the battery did nothing. Still have the flashing amber light and it goes dead when I unplug it. I also changed the CMOS battery, to no avail. I think it's the motherboard. The laptop I have is over 4 years old, so I think it's past its lifespan.
I am using Linux Mint, BTW.
Ask for a new battery. The first battery that was sent was dead. The 2nd one worked.
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 84
crwdns2936753:030crwdne2936753:0 367
crwdns2942667:0crwdne2942667:0 26,432
I have a samung galaxy. S5 phone shows 100%charged unplug charger phones dies won't turn bk on unless charger is plugged in why
crwdns2934271:0crwdnd2934271:0 Rochelle McIntosh crwdne2934271:0
my school computer charges to 100 so i unplug it and then it turns off and when i turn it on its on 1 percent
crwdns2934271:0crwdnd2934271:0 Gio Venegas crwdne2934271:0
