Find repair and further information on the Whirlpool GI7FVCXW*0* refrigerator—a bottom freezer model equipped with an ice dispenser, automatic defrost function, and an anti-sweat heater switch. This page covers information for model numbers matching the pattern GI7FVCXW*0*.
Whirlpool GI7FVCXWY01: Bad Evap Fan in Refer Compartment Question
On Whirlpool GI7FVCXWY01 Refridge, I have a bad evap fan motor. Before replacing, everything else with Refrigerator is working fine. When I install the new Evap Fan Motor the refrigerator keeps trying to start up, but quickly shuts down and the electronic door screen cycles on and off. If I remove the evap fan from the circuit, the refrigerator works fine (but still without a refer evap fan). Any ideas? Did I get a bad evap fan motor from the supply house, or is there something else going on here? My evap fan is a 14V DC motor and when I check the supply line I am getting 14V DC to the fan motor. What cha think?
Thank you,
Tom
@ladytech may be able to assist you
Hi @tdobb
Are you sure that you ordered and/or got the correct fan motor replacement part?
The links below both show that it is OEM Whirlpool part # W10276647 and that it is a 12V motor and not 14V as you state you have.
This link shows that the evaporator fan motor is a 12V motor and not a 14V motor.
This link to another supplier shows the same information, see part #26
Here’s an enlarged image from the first link showing the information on the motor.
(click on image to enlarge for better viewing)
crwdns2886500:0Evaporator motor and harness assembly with thermostat, sensor, fuse, and plugs for Whirlpool and related brands.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Whirlpool Evaporator Motor - W11334745
$70.99
Thank you for your input, but yes, I ordered the correct part which matches as you state above OEM Whirlpool part # W10276647. But, the website does state that it is a 'replacement part for the original; original part is no longer manufactured.' If you look at the pictures above, there are colored dots on the motor. Do these dots signify anything more than test markings? Is it possible that they switched polarity or something? I'm stumped and this has me baffled... thanks so much.
@tdobb
Bit confused by the "....website does state that it is a 'replacement part for the original..." as the links that I posted show the part number to be genuine OEM or manufacturer's part number.
Also you said that yours was a 14V motor. is this printed on the motor or just what you gather from the value of the supply voltage?
Sometimes the supply voltage can be a higher value if you measure it with the load disconnected i.e. open circuit voltage.
When searching online using the OEM part number as the search term, every image of the motor shown by various suppliers show that it has 12V printed on the motor
Hi Jayeff, - Both the old and new motor are rated/printed at 12V DC. I am getting 13 -14V at the supply wires. Thanks much!
@tdobb
Looking at the image it is only a two wire connection and hopefully the fan connector only fits the one way into the harness plug.
If it fits both ways then usually the convention is that red is +ve. (red on the component i.e fan motor that is)
When testing for DC polarity you can use a DMM voltmeter to find the +ve leg of the supply.
Place the DMM's DC Voltmeter red V test lead on the +ve leg and the black com lead on the -ve leg and it will read 14V
If you reverse the test leads it will read -14V i.e. -ve (negative)14V
So the position of the meter's red V lead indicates the +ve of the supply, as +ve is the default display i.e when no -ve symbol on the display.
Did you measure the resistance of the DC fan motor winding on both fans?
Using Ohm's Law I worked it out at ~34 Ohms given that the power is 4.2W as stated on the image and the supply is 12V. But then again it has been more than 50 years since I was taught it so my memory or my maths or both may be wrong ;-)
Apologies if you know all this already
SOLVED! I did get a BAD Evap Fan Motor from the supply warehouse. When I installed the replacement, everything is working as designed. Thanks for everyone’s help on this! Stay safe, stay healthy, Tom
tdobb crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 515
