Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
crwdns2934591:0630crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Messed up screen need help
When I woke up this morning my iPad had a light but visible layer of white and white lines it affects things like the app Andy every thin but it is purely a visible problem I don’t know how to fix it and ideas?
Hi,
Firstly, has the iPad been knocked or dropped? This could have damaged the LCD, or disconnected one of the flex cables. This could happen anyway, even without a drop, but less likely.
The other problem it could be is a motherboard issue, it water has got inside, or the iPad has been opened up and tampered with in the wrong way. If there isn’t a possibility of either of these, then most likely a disconnected cable, which can be fixed simply by opening up the iPad, disconnecting the screen, and reconnecting it.
Please remember to disconnect the battery if you try this as to not fry the backlight!
Absent Kiriko crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 34
