Sim card slot not working
Hello., Water enters into my sim card slot and as a result my phone can not detect any sim cards. Can this problem be solved? How?
As you know water, and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion is ongoing and doesn’t stop until it has been cleaned away.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents or other additives and is not as effective. If you do use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
You don’t say the model number of the phone but if you search on YouTube for Oppo (insert model) teardown or Oppo (insert model number) screen replacement, there may be videos that show how to disassemble the phone so that the battery can be disconnected and then the phone can be inspected and cleaned etc.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
crwdns2942667:0crwdne2942667:0 1,327
crwdns2942205:01crwdne2942205:0
My sim slot locked permanently
crwdns2934271:0crwdnd2934271:0 Bonisile Nzimande crwdne2934271:0
