Why is my muffler glowing red hot starts right up and seems to run
Meffler gets red hot and glow when full throttle starts fine does not boggle but does seem week
The reason the muffler is glowing red is because the exhaust temperature is off the chart.
This (highly likely) means that the ignition timing is out, or the fuel mixture is too lean. One possibility on small engines that run a flywheel magneto is that the keyway/key may have damaged itself or sheared off, allowing the timing to go out. Or, the carburetor is gummed up, not allowing full flow of fuel.
What does this mean? Well aside from the engine going outside of it's safe operating temperature (wearing out components faster), it can also lead to detonation, which is where the fuel is igniting before the end of the compression stroke. This can result in breaking the connecting rod and destroying the engine.
I would not use it without making adjustments.
Sounds like its running lean at the high end. Double check the fuel/oil mixture is correct. Also the high rpm has a mixture adjustment on the carb. Best to have someone that has adjusted those before to get it set correctly.
I have just experienced this problem and the results were devastating. The muffler is bad replace it right away or you will be dealing what I am dealing with. The red hot muffler caused the engine to over heat, it blew the oil right out causing a whole engine rebuild! And getting parts for this thing is ridiculously expensive and that's if you can find them. The muffler is expensive I paid $640 for mine. Before you can get it replaced your engine will burn oil bad. Keep a close eye on the oil or you will be in the same boat as me.
I have a 85 chevy astro van 2.5 that will start and idle fine but the exhaust manafold glows red in minutes there is not cats on it and the exhaust is not blocked the dash light showed code 42 so I replaced the icm but that didn't work it back fires and u can only get in 2nd gear 20mph to the floor I'm at a loss iv tried plugs wires coils icm grounds and vacuum lines iv pulled the exhaust off and let's put it this way I could use the flame that's comes out as a cutting torch
Put a fuel pump on the Astro van and it will fix all the other issues
It can be caused by a clogged catalytic converter. It can also be caused by timing being off
It get red hot and bogg
crwdns2936751:024crwdne2936751:0 50
crwdns2936753:07crwdne2936753:0 271
crwdns2936753:030crwdne2936753:0 1,154
crwdns2942667:0crwdne2942667:0 46,652
