Iphonw 7 after audio ic repair homw button stop working
Its happened to me 4-5 time I don’t understand audio ic have nothing to do with home button need help of you guy to solve this Problem
thanks
thanks
This happened to me when the 7 first came out. It turned out my technique in removing the screens was the problem as it was creating a small tear in the home button flex. Check the home button flex under your microscope and you will probably find a small tear at the 90 degree bend.
But how come i did not tuched home button i repaired audio ic
Chris is referring to the flex that goes from the screen to the logic board. This is a common issue. Look at the flex carefully at the 90 degree bend, even the lightest tear will cause issues.
Usually homer has been knocked or its has flux under it when doing audio IC this will cause the home key to have no return feature.
Do you have an error with touch id on screen? If so s Chris has mentioned it could be a torn flex on the screen.
Cheers.
Yes i will check and reball homer ic let you know later
No problem hope it helps. Good luck
Still same i reball homar ic
Did homer look like it was damaged?
Also can you confirm that you don't get touch id error?
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 362
After the Audio ic there is homer ic
If It short or damage cause home button error
crwdns2934271:0crwdnd2934271:0 HMD Mobile Repairs crwdne2934271:0
It because after the audio there is homer ic.if its short or damage home key will not work
