Repair guides for the Huawei Mate 20 Lite Android smartphone, released in September 2018. Model numbers SNE-AL00, SNE-LX1, SNE-LX2, SNE-LX3, INE-LX2.
No display on my Huawei Mate 20 Lite
Hi,
I have no display on my phone when I press the power button. I have attached a video of the problem
Your help is much appreciated
Thanks
I have the same problem. Did you solve it ?
did you break the LCD screen it could need a new screen or battery
Hey Adeel ;
I can see the back light is being blocked by full contrast from display . Did it drop hard? was screen replaced ? If it were me I would find a tear-down video and double check any of those ANNOYINGLY small connections . Dunno if it will be a case of reflowing the “lead” free solder with heat . Severe drop can crack mobo tho .
Factory reset procedure should not be bothered with , unless you dont care and are curious if it helps . I dont think that would do anything .
PS ! caveat ! reset may cure accidental screen bright down to zero . In a dark room can you see any hint of images ?
Good luck
Hugh
Adeel Hussain crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,982
