Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
Trying to use clear TV antenna
I have a Mitsubishi VS-50111 television that I'm trying to use a clear TV antenna on and all I'm getting is the snowy screen.
Please give us the model number of your antenna.
Hi @nottechnically,
a). Check that the TV antenna is plugged into the Ant A input on the back of the TV. (see image below)
(click on image to enlarge for better viewing).
b). Ensure that the Ant A input is turned ON. Go to Main Menu > Set Up Menu > Input Assignment Menu (see image below green boxes)
c). Scan for available TV channels using the Memorize Channels feature. Go to Main Menu > Memorize Channels (see image below red boxes)
Here’s a link to the user manual if you need to know any further information.
Be aware that the Clear Antenna will only receive free OTA (over the air) TV channels and not cable TV channels.
Maybe your installation is wrong. If you want to install the TV antenna correctly, you can check out this article.
Sandra Thompson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 299
