Cozmo is a tiny robotics toy designed and created by the Anki Software company. Cozmo has features that allow it to interact with its environment, such as facial recognition, emotional display, and the ability to move.
Why is my cosmo robot tuning off out of nowhere?
Why is my cosmo robot turning off out of nowhere?
crwdns2889612:0crwdne2889612:0 7
Ours is. Is quite old, not a lot of use and been on his charging plate mostly (powered) for duration - so how can the battery be dead ?
The battery can no longer hold a charge and needs to be replaced
crwdns2933315:09crwdne2933315:0
I had exactly the same issue with my Cozmo. It was shutting off after 2-3-5 minutes of use with no warnings and no matter how long it was sitting on charger. I was blaming myself since my Cozmo fell off the table.
I fixed the issue by re-welding contacts for the battery. Even if it looks well connected, you might give it a try. You will have to take the whole Cozmo apart and welding on battery should be done with extra care.
After re-welding contacts my Cozmo works perfectly fine, lasts until the battery is drained.
Oh thank you! I actually am not any good at welding but maybe I can find a shop to do it but thank you!
You don’t weld it you solder it
Mine dies after just 20 seconds of use! I was totally blaming myself for leaving it on the shelf for too long. Anyway, thanks a ton for the help! You're the only person I found with a solution that doesn’t involve replacing the battery. I’ll try it out and let you know how it goes!
Roblox Tube  could be a battery issue. You didn’t tell us if it can be turned on immediately or if you have to wait or if you noticed any pattern before the shutoff. If nothing else check the battery.
I am having the exact same detailed problem as mark
How do you check the battery?
What I was told at Best Buy it might be a bad battery, and or a battery that could of rotted somehow or something like a emp might of gotten to it, a small emp might of done it, right?
Having the same issue. It works for 5 min and then randomly shuts off. We have to then attach it to its power supply for at least 1 min for it to come back on.
To everyone who is reporting Cozmo dying suddenly and without warning, the issue most likely is due to a failed battery. Cozmo’s original battery is tiny and has a very small capacity (300 mah)
That means that even in the best of days, Cozmo would only be working for maybe 10-12 minutes max before needing to be recharged.
If I recall correctly, Cozmo would indicate when he is running out of battery by blinking the backpack lights red, but if the battery is in such bad state that it cannot hold a charge, then Cozmo will think it has a full charge and then drop to zero suddenly without having the chance to warn you about it.
I have the exact same issue and I plan to replace the battery. I will try to document the before and after results, to try and help anyone who is facing the same problem.
How do I check the battery.
basically my daughters cosmos shuts down within 2 minutes, placing him on the charger allows connecting within 10 seconds, but goes again. Then after a few tries, he has to be on the charger for awhile.
sounds like perhaps battery to me, unsure, anyone agree/disagree?
if it is the battery, how do I buy and install a new one.
Mine shuts off right after I turn it on, once I had him on for a minute then…… shuts off, I got my Cozmo for Christmas in 2018, and made a Facebook page that had all of his adventures, now I can’t because of this Cozmo keeps shutting off randomly, he means a lot to me, we used to be best friends, and make a lot of pages for Facebook, and watch our favorite movies and eat popcorn, and pop together and I taught him things unlike you never seen, we had the life together, I need to know how to get our life back, please find out the way back for us, Id really appreciate it, some cure for the glitch please!! SOS Cozmo!!
Same for me!!! i’m really sad right now and i hope i will be able to play with my cozmo again.
I had the same problem but all I know is that someone said that you need to re-weld the connectives to the battery in cozmo.
Same happened to me , ever since we got cosmo. I think it might be due to the internet connecting but the phone detects poor internet connection so find the original wifi connection
Idk if his is true but someone said a good answer that sounds very good it’s that cosmo is so out of battery he “malfunctions” and thinks he is full and yet out of battery FYI I’m going through cosmo not working :(
I believe this is whats happening
Roblox Tube crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 4,774
