Black Screen after it fell
MySamsung Galaxy A70 has a black screen the phone works I can hear it when someone calls or when I restart it but the screen is black any help full suggestions
crwdns2889612:0crwdne2889612:0 7
crwdns2944067:07crwdne2944067:0
Yes I can hear alarm sound
All r working well but in a corner black and parpel sport in the screen
It’s makes a little sound when I charge it but it won’t turn on what can I do pls someone help me
@Adam Lasri anything happened to it? what have you checked?
@oldturkey03 it fell then the screen went black but you can hear it and everything so what dose it mean
crwdns2934275:02crwdne2934275:0
Ik this is from a while ago but just in case anyone else is having this problem, i had this exact problem but when doing a soft reboot the screen became white and pixelated, like an old school tv. I massaged the back of the phone and that seemed to reconnect whatever wire came loose and made the screen work again.
Thanks dude, this massaging trick fixed it for me :)
I thought I would’ve had to spend a couple bucks to save this thanks for this trick
Zweber Steyn  since this happened after your phone fell and you already tried a restart, it stands to reason that this is a broken display. Of course, you always want to check for loose cables etc. but be prepared that this may need a new display. Here is how to do it and displays are available at places like this and many more.
i actually got this problem and knew it was a loose cable because my screen was replced so i opened it and found only 2 screws the other were stolen so i disconnected the battery grabbed flat surface screw driver and placed it between the plast layer cover already removed then i clicked on the battery to lower card and it got plugged in and now my screen works just fine.
Zweber Steyn crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 13,190
