The Odyssey was introduced in 1994 as Honda's first minivan — based on the Accord platform, with a 4-cylinder engine, all-disc anti-lock braking, all wishbone suspension, and a four-speed automatic transmission with a steering-column-mounted shifter and a hill-hold feature, marketed as Grade Logic.
Why is my transmission light flashing
The transmission system doesn't select well whenever the drive light on the dashboard goes off
Hi,
Check that ATF (automatic transmission fluid) level in the vehicle is at the correct level and that it is clean and doesn’t smell burnt at all.
The transmission fluid should be replaced every 48,000 Km (30,000 miles)
Okechukwu Chukwu crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 182
