(Pierre Cardin PC7001) Looking for ANY resources.
This is a craptastic tablet and I’m quite frankly shocked that there are literally zero references to it on iFixit and minimal non-advertisement references elsewhere. To nobody’s shock, Pierre Cardin’s website is useless.
I’m looking for literally ANY support resources about this tablet. Owner’s manual, software updates, an official spec sheet, etc. The closest I found is this manual for a PC7015 which is similar, at least…
https://fccid.io/V97PC7015/User-Manual/U...
…which contains such Pierre Cardin-ish language as, “It is also equipped with a piece of touch LCD of high definition, which can be used to watch vedios (sic) and pictures of high definition.”
It also has a section for “Restore Factory Settings” which says there are two ways to perform a factory restore, then gives instructions for one method.
Anyone have any leads?
Hi @secondlife
No leads regarding the tablet but it is interesting what a search for a Pierre Cardin PC7001 turns up.
Have found links where it says that it has Android 2.2 loaded so perhaps the standard Android hard reset procedure (or variation thereof) might work, i.e. Power + Vol Down (Vol Up?) to get into recovery. Apologies if you have tried this already
If no good then open it up and find the CPU make and model. You may be able to find custom firmware that may suit it e.g. if it is a Rockchip RKxxxx then try FreakTab.
If other cpu makes then Google the make and model or check XDA developers and see if there is anything on custom firmware for the cpu
Steve crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 112
