The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
CMOS battery on Asus x540y
Where is the cmos battery on Asus x540y taking the laptop apart and can not find anywhere.Please show step by step on how to find and replace.
I have laptop Asus X541U, this model does NOT have Cmos battery. Cmos is kept by capacitor, living off the big main battery. May be X555L has the same design.
Shane Wigum it may not have one. If you removed the motherboard take a look underneath the board. IF you cannot locate it there either it is easily possible that Asus is using a capacitor instead of a CMOS battery. It would get power from the main battery. Anyhow, let us know why you need to replace it and post some good pictures of your motherboard as well as the chassis with your question so that we can give you a more precise answer.
Adding images to an existing question
hi
there is no cmos battery in your laptop model just the main battery of laptop
crwdns2934073:0crwdne2934073:0
Shane Wigum crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,040
