Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
fireoscaptiveportal generate_204 Setup Firestick
I’m trying to setup my new Firestick but it keeps getting stuck on the joining network page. The screen shows a white box and the message includes a link to fireoscaptiveportal generate_204
Any ideas on what to do please? My internet is working perfectly on my other devices.
crwdns2889612:0crwdne2889612:0 90
crwdns2944067:019crwdne2944067:0
Any solutions to this issue?
I get the same screen, but in the middle of watching something. Rebooting everything seems to help but is really annoying.
net::ERR_NAME_NOT_RESOLD
How to setup my WiFi Repeater?
What is the username and the password for my WiFi Repeater
crwdns2934275:014crwdne2934275:0
crwdns2933315:09crwdne2933315:0
which type of frequency your wifi works on? 2.4 or 5 ghz?
If your router is syncing the two then there might be your problem (you should change the setting of your router to get out 2 ssid one for the 2,4 and one for the 5ghz and then you try to connect on one or the other to see which one works
crwdns2889612:0crwdne2889612:0 57
crwdns2944067:011crwdne2944067:0:
I do not want to change any settings on my router as ‘all’ other devices and services appear to work without an issue, as does another fire stick on another TV, any other ideas?
Thank you,
I agree the television works perfectly with the aerial by I want to use the other facilities as well
i reccently changed passwords on my wifi
i changed password recently, cause could be time of day or due to my amount of activitie?!
This answer is completely useless and does not address the actual issuel
crwdns2934275:06crwdne2934275:0
It’s the BT home hub smart setup. Go into advanced settings on the router and disable smart set up. Everything will work perfect after!
crwdns2889612:0crwdne2889612:0 8
je ne comprends pas votre langue !
i dont know how! everything wAS Fine, until i changed psw"s all other devises work ok!
it tells me ; access blocked!
Press the three lines on your fire stick remote and then press select and forget the network then find the network again and enter your password to log into your router again and go to the home screen on the fire stick and they should work if it doesn't work the first time repeat the process until it does this worked for me today on January 24th 2022 good luck
Yea. Worked on reboot of the device
i made the stick “forget’ my router and reconnected and it worked
crwdns2889612:0crwdne2889612:0 7
crwdns2944067:012crwdne2944067:0:
I tried but that didn't work either. I even tried with phone hotspot but it didn't work
it is working now thanks for help
Just do forgot network and reconnect it. It will work. I have did and successfully connected.
Same issue .. My solution was forgetting the network, resetting the firestick and reconnecting to the network again :) .. works fine now!
by resetting the fire stick you mean ?
crwdns2934275:07crwdne2934275:0
Unpaused firetv please I want to watch tv
I don't know how to put my Xfinity ID in can someone please help or call me.
Can someone please help or call me something is on my tv screen to connect to NOW WiFi Pass
my email is lindafmills@gmail.com
No puedo usar mi fire tv porque no conecta el internet
bonjour, pour que je comprenne , il faudrait, m’écrire en français, je ne comprends pas votre langue, que vous chercher à nous imposer, tout le monde ne parle pas anglais, merci de revoir votre copie
bonjour, je voudrais que nous donne la solution pour installer OQEE by free avec amazon fire tv stick qui rend soin disant une ancienne tv en en téléviseur Smart , merci
eu ce problème aussi le 24 janvier 2022. SOLUTION : Réinitialisez le Firestick en usine et cela fonctionnera. Et si vous ne savez pas comment réinitialiser, maintenez simplement la flèche droite + le bas de la télévision (en bas) pendant 10 secondes et il vous demandera de réinitialiser le firestick. Merci
bonjour
moi jai le meme probleme. sauf que jarrive pas a me connecter a internet. cest ca le probleme. je suis dans 1 hotel. le meme depuis 2 mois. ca fonctionnait parfaitement puis soudain bam non!. le portail de lhotel saffiche, je peux entrer mon email mais quand je fais connection: il mamene a la page blanche err not responded. fireportal generate 204. jai tout essayé: débrancher la firestick, vider les caches, vider les cookies, essayer de passer par silk( mais je suis pas capable puisque je nai pas dinternet). a laide!!!!!!
Don’t know why it’s not working
All of my TVs say paused? Anyone have a for this?
Sam crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 175
crwdns2936753:030crwdne2936753:0 702
crwdns2942667:0crwdne2942667:0 70,349
