The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Upgrade Wifi card on ASUS X555L
I want to upgrade the wifi card that its can be support on 5Ghz WIFI , what model is recommended?
Hi,
The following WiFi / BT module is shown in the parts list for an Asus X555LA so at least it should work
It is an Asus 802.11A/B/G/N/AC WLAN+BT4.0+HS module . The part number is 0C011-00110200
If you search online using the part number only in the search term of your browser, you will get results for suppliers of the part.
Hopefully this is of some help.
thank you so much for the information! ill find out =]
zangiamit91 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 5,577
