Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Docking port corroded by water.
Water was wicked in by sitting iphone up right on wet towel cloth everyday for about a week at gym.Connection are corroded and phone will not turn on,don't no if I did further damage by shorting something out inside or do I just replace the dock?
First things first, hopefully it isn't too late. Get the phone dry. Not just the outside, but everything inside too. This means you'll need to open the phone, and dry it out some how. A good way is to leave it in a bag of uncooked rice for about 24 hours.
After you are completely sure the phone is as dry as the Sahara desert, try turning it on again. If it still doesn't turn on, You'll need to start replacing parts. Here are the first few I would suspect:
  1. Dock Connector
  2. Battery
  3. Display Assembly
  4. Logic Board (bad news)
If it is the logic that went bad, then your best opportunity is to sell the working parts on eBay and using the money to buy a new phone.
EDIT: Don't use a hair dryer (or other heat source) to dry the phone, or you'll just ruin your phone.
crwdns2886500:0Replace a 1150 mAh battery compatible with iPhone 3G and fix problems with charging and battery life.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone 3G Battery
$14.99
crwdns2886500:0Replace a scratched or cracked front glass panel or a malfunctioning display for your iPhone.crwdne2886500:0
iPhone 3G Display Assembly
$59.99
crwdns2886500:0Replace the 30-pin docking port assembly in an iPhone 3G and fix problems connecting to USB devices, charging problems, loudspeaker audio, and microphone functions.crwdne2886500:0
iPhone 3G Dock Connector
$9.99
You won't be able to just replace the dock, I'd say your motherboard is shot so it will need to be replaced. Even if you could replace just the dock, most likely the motherboard would be nonfunctional from water damage or shorting out.
I gave you a - for jumping to conclusions... not all waterdamage kills the entire phone or is irreversible.
True.. good point. There are many times when the motherboard is salvageable, thanks for the input.
Anthony crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,976
