The 6th-generation Surface Pro, released in October 2018. Available in platinum and black. Model number: 1796.
Why is my device not charghing?
So my tablet is plugged in but is still not charghing.My biggest problem it’s that it shutted down before I could try to solve the problem from the settings.Can someone please help me to figure out what it’s going on?Should I buy a new charger?
@secretgirl I would not just go ahead and replace the charger just yet. Measure the output of the charger with a multimeter and see if it has the required voltage. If so, not reason to replace it. If is does not then you replace it. After the charger you will have to check the charging port. Check for debris, corrosion, bend pins etc. Clean it with a few drops of 90%+ isopropyl alcohol and a few puffs of canned air. If that does not resolve it you will have to take your Surface apart. There you would need to check your charging port connector as well as the power management IC. Even so this is not a guide, it’ll show you what you are up against. So, start by checking the charger first.
Microsoft Surface Pro 6 Teardown
Secret Girl crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 323
