Repair and disassembly information for amplifiers in home audio systems.
VSX819H amp wont enter service mode
Hi, My pioneer VSX 819h went into protection mode. It now won’t enter service mode. I’m following the service manual. The only thing it does is turns on for 4-5 secs when pressing power button+adv-surround which according to the service manual is used for clearing the error counts. Thanks
Thank you for this question. You mentioned how to enter service mode. (Power+ buttons) and that seems to have cleared my problem.
The unit seems to be working now. Thank YOU!
So yeah… I was able to turn it on, but after reconnecting it to the other components and powering it up it only worked for less than a minute.
But still, Thank you and I look forward to learning more.
JZ
Until you resolve the protect mode, the amp will continue to work as you see it. Protect usually indicates that there is a short in the output section and the amp shuts down to prevent further damage. Since this amp uses discrete transistors for outputs, check each one for a short. Once found, change the entire pair (2SD and 2SC transistors) and any other components in the area that are effected.
Dan
ThreeTwoBravo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 237
