Wow, looks of work for no results. There’s only a couple of things left to try:
Door Switch
The door switch turns off the ice and water dispenser when the refrigerator door is open. If the door switch fails, the dispenser will not turn on. To determine if the door switch is defective, use a multimeter to test it for continuity. If the door switch does not have continuity when activated, replace it.
Door Switch WP2149705
Genuine OEM Part # WP2149705RC Item # 438889Alternative Part Number(s)
Icemaker Mold Thermostat
The icemaker mold thermostat monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature, the icemaker ejects the ice cubes and refills the ice mold with water. If the mold thermostat is defective, the ice maker will stop making ice. To determine if the thermostat is defective, use a multimeter to test it for continuity. If the mold thermostat does not have continuity, replace it. (Note: If the ice maker is not cold enough, the mold thermostat contacts will open. If the thermostat contacts are open, the ice maker will not make ice. The ice maker temperature must generally be lower than 20 degrees Fahrenheit for the thermostat contacts to close.)
Refrigerator Icemaker Mold Thermostat WP2321258
Water Filter
A clogged water filter can restrict the flow of water to the dispenser and prevent the ice maker from working properly. The water filter should be replaced about every six months to maintain proper water flow and ensure water quality.
Water Filter EDR1RXD1
Genuine OEM Part # EDR1RXD1 RC Item # 4248262Alternative Part Number(s)
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
Hi @helpusplease ,
What is the model number of the freezer?
Does it have two water intake valves, one for the water dispenser and one for ice maker?
Have you checked if there is power getting to the water intake valve for it to operate when water to fill the ice tray is required?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Hello @jayeff
Whirlpool refrigerator model #WRS325FDAM1
It has one water intake valve in the rear of the unit that I replaced with Whirpool # WPW10179146. One line for the water dispenser in the front (which works fine) and one line for the ice maker (not working)
Not sure how to check for power to the water intake valve. The new one installed did not help resolve the problem. I also installed a new ice maker. Whirpool #WPW10300022 and still no ice. Water pressure is good and line to ice maker is not blocked.
crwdns2934271:0crwdnd2934271:0 Jim crwdne2934271:0
