A 6 megapixel camera in Panasonic's Lumix series released in 2006.
crwdns2934591:05crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Camera Will Not Power On - Was working previously
Hi,
I received a Lumix DMC-FX3 camera which had the lens jammed open due to sand getting in the mechanism. But it powered on then shutdown.
I manged to disassemble the lens and clean out the sand.
I tested the camera while still disassembled and it seemed to work - the lens mechanism was still a bit noisy so I decided to remove all the grease and clean it thoroughly before applying fresh grease.
When I assembled the unit - it now longer powers on.
There is no sign of life - no flashes from the LED no noise from the motor.
I charged the battery and checked & cleaned all the connections with isopropyl - but still nothing. Completely dead.
It seems to me like a protection fuse might have gone - but I can't easily find on on the pcb.
Does anybody have any experience of this camera?
Or have the service manual for it?
Thanks,
Mark.
markiexxxx, here is the service manual. It does have the schematics, diagrams and parts list for your camera, hope this will help. Good Luck
oldturkey03 - I have the similiar problem, with lens zoom issues, could you please provide access to the manual to caravanwalks.
Thanks in advance
Update
thanks very much have accessed the information, now need some time to strip down the camera :-)
crwdns2942205:01crwdne2942205:0:
it should be back up. Use the link from the above answer. I do have to remove them every now and then since I only have limited bandwidth....;-) contact me on my email in my profile if you can not download it. Good Luck
Does anyone know where you can get the 'Extension cables for servicing' from? Testing is impossible with the circuitry all assembled :(
Would you by any chance have the part number for the cable?
Hi,
Yes they are:
VFK1951
VFK1974
VFK1950
VFK1951
RFKZ0362
VFK154
Thx
markiexxxx crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,863
