Have to spin clothes twice to spin them out
Have to spin clothes twice for them to spin
Assuming the TUB IS SPINNING but does not get the water out of your clothing…
– Make sure the washer is programmed to the correct wash cycle, different cycles have different speeds!
– Make sure the drain hose on the back of the washer is not clogged or bent.
– Check that the drain hose on back of washer is positioned correctly in standpipe and is able to drain properly.
– Check the drain pump debris filter or coin trap, objects may be blocking the water flow.
– Check inside drain pump and all hoses connected to drain pump for foreign debris or small pieces of clothing.
– Be sure the wash load of clothing is balanced, balance out the wash load if you see all clothing to one side.
– Check washer belt to be sure it is not stretched out or damaged. (for most top loaders)
– Check direct drive motor coupling system to be sure there is no visible damage. (for most front loaders)
– Lid switch or door lock assembly may be damaged or bent and not making the electrical safety “connection”.
Water flow is fine! Just have to run spin cycle twice. The PROBLEM is not enough centrifugal force over the time allotted on the controller.
@charlesgribble Sorry to have to be the one to tell you, but Richard Mayer, or "mayer" as he is known on iFixit, passed away some time ago, so you're not going to get an answer from him. I would suggest you start a new question under the proper category and be sure to include the model number of your washer.
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 166
crwdns2942667:0crwdne2942667:0 5,441
Please give us your exact model number so we can give you a more precise answer.
crwdns2934271:0crwdnd2934271:0 mayer crwdne2934271:0
