The Samsung Galaxy Tab 4 10.1 is the fourth generation of Samsung tablets that has a larger screen, higher camera resolution, and 1.5 GB of RAM.
Why Wont my screen respond to touch.
Why wont this work. The near middle of my galaxy screen will not respond. Leaving me to not type in numbers. I have to flip the screen in order to do so. And the power volume thing does not work. This is the best thing I have and I don't want to throw it away now
There is a fix for this. As there is a repair guide, you should be able to repair this issue, firstly, the touchscreen may be a bad connection to the motherboard, id advise you to first find a repair guide for the Galaxy TAB 4, secondly, once you feel confident, you then take off the back cover, find the touch/lcd connector, take the connector off, put it back on, if this doesn’t resolve your issue, then buy a new screen, put it on the frame. If this doesn’t fix this issue, then it needs board level repair, secondly, check the volume buttons, are they connected right? Check for that, you can find replacement parts anywhere, and good luck on your repair! Merry Christmas!
1) Replace the power button.
2) maybe some of the thing inside loose. dismantle it check.
ItsPsychoGames crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 297
