The Razer Blade Stealth are a line of premium Ultrabooks by Razer. The latest model is the Razer Blade Stealth (2019)
Razer blade stealth 13.3 (2017) not turning on
Help! My Razer Blade stopped turning on out of nowhere. The light on the power adapter still turns on but non of the lights on the laptop turn on. I have tried the basics such as holding down the power button for a couple of seconds and removing the battery and plugging in the power adapter but nothing has work so far. If its the mother board is there somewhere I can get a replacement? Thanks!
If your Razer Blade won't power on, even when it's plugged in could have a faulty power supply, battery, motherboard, video card or RAM. As you have troubleshoot the laptop with the basics. It could be a problem with an internal component.
That way more in-depth troubleshooting is required and a hardware repair may also be necessary to fix the problem. I suggest contacting the manufacturer of the laptop for recommendations on how to get it repaired. You can also take your laptop to a computer repair shop, as they may be able to diagnose the issue and replace the faulty hardware.
Same problem here. The adaptor is good. The adapter connection port is good. Disconnecting and doing hocus locus with the internal battery connection has not effect. No lights on what so ever. Big time dead. It died with battery half full - just went into deep slumber! Even tried another battery and running with no battery. Did not hear pop sound I have read about but suspect it was the micro capacitor failure in a hard to get to spot that I have read about. Thanks razer
julie.morin51 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,713
