Repair information and troubleshooting for the Harman Kardon Aura Studio 2, a bluetooth speaker with a microphone made by Harman Kardon and smaller than the Aura.
sound distortion on heavy bass
My harman Kardon sound sometimes distorts on music with a heavy bass
crwdns2889612:0crwdne2889612:0 8
Mine too. The Aura Studio 3 speaker is distorting. It was ordered to replace the Onyx Studio 6, which was returned for the same reason. Both speakers FUZZ out, with lots of skips. I am strongly leaning toward another return to Amazon. So disappointing.
Quel TRAGIQUE!
crwdns2933315:07crwdne2933315:0
Hi Jay,
I tried to follow your advise , but still makes same sound distorted , but today I tried plugging in my stereo earphone it sounded perfect the bass works nice even in low bass sound. I was thinking it was really a bad speaker coil that produce such a distorted bass sound.
Sam
This is common with these types of speaker systems. The Harmon Kardon Aura has built-in equalization and protection circuitry, but it can only do so much. Heavy bass can sometimes overwhelm these circuits and the small bass speaker. You can try turning down the bass settings, either in the Aura itself or through the source you’re playing the music with. If you still have distortion regardless of your tone settings, then there may be damage to the bass speaker in your Aura. This can happen over time if the speaker is overdriven. Replacing the bass speaker is possible, but it’s not an easy task since the Aura isn’t designed to be taken apart very easily.
please provide a direct solution to the problem wether to change speaker or what part number or value of the speaker it self . how to purchase this type of speaker.(HARMON KARDON AURA STUDIO 2) Thanks.
the speaker won't need replacing or fixing, if it does it will only happen again if listening at the same volume with the same audio files, if its only intermittently its the track itself (due to compression of audio files when recorded or converted into mp3 or lower quality formats) each recording will be slightly different that's why its only happening sometimes, its always going to struggle with really low bass from the size of the speaker (normally an 8" or over is best for strong bass) and its capabilities especially over Bluetooth , it will only handle a limited frequency range and will struggle at the bottom end especially if on a louder volume, try lowering the bass or volume that may stop it.
My son took a bottle of water with cap on half full and set it on top of it plugging up the hole could that blow the speaker
Also right plug it but when using loud Bass it just shuts off do not know if that was caused by the bottle or if it is caused by not having the right cord it plays music and everything just fine but that's off when you play Loud bass music
What was the cost to repair my speaker
I have this problem too. I bought one for 99$
Hk onyx 7 Studio and i had it for one week, barely playing it. Then all of a sudden a song played and the bass sounded distorted. I changed quality and it still did not sound good. I didnt have full volume.
Im on my way to see if i can replace it. I havent tried it. But from reddit they unplugged the power cord. And that seemed to work. When it happened i had the cord in. Anyway. We will see.
Jag har prövat med att dra ut laddningskabeln. Det funkade. Basen skorrande inte då.
My Harmon Kardon Onyx Studio 2 had booming bass and distortion issues. There was a two button combination that would change built-in equalizer setting: Hold Bluetooth button and - for ten seconds for bass. Hold Bluetooth button and + button for tremble.
The settings wouldn't hold. I ended up buying a Studio 2 motherboard from a vendor on eBay located in Lithuania for $30, and the replacement solved the problem. The repair required special torx screwdrivers, but was otherwise and DIY easy fix.
Sangeeta Maharaj crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 15,625
