Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Digitizer does not work after screen replacement
I replaced screen and digitizer and it seems everything went fine. The phone turns on but the touch doesn't work, the back and all app button do work. I tried doing a factory reset but it stills doesn't work. What could be the problem?
Hi Neil,
I would suggest disconnecting and re-seating the display cable. Carefully check the connector for any debris—the pins on the connectors are tiny.
OnePlus 3 Screen and Digitizer Assembly Replacement
Hello Arthur,
I tried disconnecting and re-seating the display cable as you suggested but still nothing. Could it be a motherboard problem or should I send back the display+digitalizer and try with another one?
Hey Neil,
It could be a motherboard, though I'd think that the display may have a slightly higher chance of being the problem. Does the original screen work enough to be used as a test? Unfortunately with how the replacement is set up, it's not easy to swap displays.
Neil Considine crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 515
