vw car gets stuck in park
shift lever will not move out of park.
Most common cause of this is broken or stuck shift safety latch. There’s a lock mechanism that prevents you from shifting out of Park until you press on the brake pedal. That lock mechanism can get stuck or broken and then you can’t shift out of Park. The fix usually involves accessing the shift lever mechanism or in some cases repairing the brake pedal switch. In rare cases, it’s an ECU reflash but usually it’s a mechanical switch failure.
where are these switches and what is an ECU? and thank you for the help
The shift lock mechanism has 2 parts: a mechanical lock under the center console attached to the shift mechanism; and an electronic switch at the brake pedal up under the dash. The whole system is controlled by the car's main computer (called Electronic Control Unit, or ECU). I'm not sure where the ECU is on your Passat, but it's probably up under the dash, in the center console, or under one of the front seats. You can check the integrity of the brake pedal switch and shift lever lock mechanism, but ECU problems require a professional with specialized equipment.
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 3,635
4 liter v8 engine starts stuck in park, I can not back out of garage, help.
crwdns2934271:0crwdnd2934271:0 Robert Lee crwdne2934271:0
Does anyone know about what this would cost to fix by volkswagen dealership service
crwdns2934271:0crwdnd2934271:0 Carol Daly crwdne2934271:0
@caroldaly
Quickest way to know is contact a dealer in your location.
This is a world wide forum and since your location is not known the answer may not be relevant to your location.
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
