The RIDGID R2740 is a heavy-duty corded belt sander. The intended use of this device is meant for, but not limited to woodshops, at home and construction sites.
similar Craftsman 3x21 Belt Sander 315.117260 disassemble for repair
Upon disassembling the sander, I found that the left armature bearing failed, heated, and melted the plastic holding it in place. I can’t get the gear off of the armature in order to take the damaged parts off. I think it’s reverse threaded, but no way can I get it to budge. Help I would think a repair should be possible. Or, have Craftsman tools gotten so bad that this cannot be repaired?
Have you tried heating the part?
Hi Kevin, No, I pretty much gave up and set aside the tool. I recently found the box that I put it in - maybe I’ll give it another go. BTW, would you be interested in buying this for parts? Chris
ereplacementparts shows parts available
https://www.ereplacementparts.com/ridgid...
Chris Longwill crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 399
