Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
Blurred camera after replacing back glass
Hello everyone,
Probably not done the best repair work of my life here, and I know there are other methods of changing the iphone X back glass, but I used the “Heat-gun” method
Having a severely cracked back glass, Using a hot air gun to remove the adhesive I was able to remove all of the glass and remaining fragments WITHOUT touching or moving the camera lens cover…. the issue now that trying the camera app (or any that use the rear camera) it seems to focus in a blurred manner.
My question here would be…. what is the most likely cause? I would assume the camera assembly may have overheated and now caused the blurr ?
Yes, you have fried the rear camera. it should be removed as very sensitive to heat.
I have this problem too, so how you solve that? Change the new camera?? :((
kristian crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,136
